72 Runner evaporative control system
Posted: Tue Apr 13, 2010 10:18 pm
by ravindavid
Just put the new fuel tank in my late year 340 72 road runner. (Have done a total strip down restoration and I just about have it all back together) I have the bracket in the rear wheel well for the vapor separator, but there was never one in the car when I bought it. The car was pristine and never modified in any way. The original fuel tank had the four vent holes on the driver side. I do have the canister that mounts in front of the engine, and have been told that they changed the system mid year and eliminated the separator. It's been four years since the car was disassembled, so can't remember exactly how the set up for the ecs system was originally, but no one who worked on it remembers seeing or removing a vapor separator. Does anyone have the real scoop on this? I want this car to be just like it came off the showroom floor, so accuracy counts. Thanks!!
Re: 72 Runner evaporative control system
Posted: Fri Apr 16, 2010 4:17 pm
by 72RoadRunnerGTX
A redesign of the fuel tank vapor separator went to the production line around April 72’. Sounds like you have the earlier 71’ style design having a larger vapor/expansion tank mounted inside the left rear wheel well and a fuel tank with vent line nipples on the driver’s side. The later design used a smaller separator mounted to the shock cross-member directly ahead/forward of the tank and used a fuel tank with nipples exiting the front. Both systems had a hard vent line running forward to the engine compartment mounted charcoal canister.
Here’s a shot of the later 72’ separator.
Posted: Sat Aug 21, 2010 11:02 am
by 72Rdrnner
Regarding the evaporative control system.
Anybody have any idea about the specifications for the activated charcoal in the emission cannister on the fender well? I have searched the web and found a lot of different varieties and sizes, but don't have a clue as to what to use? Most sources are from aquarium supply places, but is that the same as in an automotive application? Or is activated charcoal the same, no matter where it's used?
Enquiring minds and all that!
Posted: Sat Aug 21, 2010 1:08 pm
by 471Magnum
What is in the rear fender well is just a vapor separator. No charcoal.
Charcoal canister was added in 72 up front next to the radiator.
Posted: Sat Aug 21, 2010 3:13 pm
by 72Rdrnner
471Magnum wrote:What is in the rear fender well is just a vapor separator. No charcoal.
Guess I didn't 'splain well enough. My car doesn't have the big vapor separator in the wheel well, but instead has the small one just in front of the gas tank, which has the vapor tubes that come out of the tank on the front.
I am speaking of the charcoal cannister in the '72, i.e. this one:
Posted: Sat Aug 21, 2010 6:17 pm
by 72RoadRunnerGTX
Sounds like you are considering cutting open your canister and replacing the charcoal? Activated charcoal is activated charcoal, used differently to filter aquarium water and likely crushed finer than would be necessary for automotive purposes. When used as part of a filtration system the charcoal will eventually become saturated and require replacement but when used to temporally absorb and store fuel vapors, unless becoming contaminated with oil and or dirt, should continue to serve its purpose indefinitely.
One thing I have found with the 72' four line two stage purge canister like yours is that with age the diaphragm the controls the secondary metering by-pass will develop pin holes and leak. Causing a higher rate of purge at idle(vacuum leak). A quick vacuum test on the diaphragm nipple will verify the correct function. Make sure to replace the filter on the bottom of the canister periodically.
Posted: Sat Aug 21, 2010 8:04 pm
by quapman
I have a spare wheel-well vapor can. If you're interested, PM me or e-mail at quapman@aol.com for price, pics, blah blah blah.
Posted: Sun Aug 22, 2010 12:02 am
by 72Rdrnner
72RoadRunnerGTX wrote:Sounds like you are considering cutting open your canister and replacing the charcoal? (edited for brevity)
No need to cut open the cannister. Depending on the size of the activated charcoal I can just put it through the bottom of the cannister then put the fiberglass filter/bottom on it to keep in in place. If the "new" activated charcoal is small enough it will fall through the grate on the bottom of the canister and fill it up as the original charcoal did.
My issue is, what "kind" of activated charcoal can I use?
Posted: Mon Sep 20, 2010 5:14 pm
by SureGrip
I hope you don't mind me using this thread to ask a quick question:
Anyone know of any issue with putting a '71 gas tank into a '72? I can't think of any off hand as the extra ports used in the evap system could just be plugged off.
Posted: Mon Sep 20, 2010 6:42 pm
by 471Magnum
71 tanks are the same as early 72 tanks.
There are no extra ports. The location of the ports is different.
Posted: Tue Sep 21, 2010 3:21 pm
by 72Satellite440
Is this vap cannister really necessary, can it just be blocked off >?
Im just curious because mine has been striiped of it and wondering if its somthing thats really necessary.
Posted: Tue Sep 21, 2010 5:37 pm
by SureGrip
471Magnum wrote:71 tanks are the same as early 72 tanks.
*bangs head on table*
Thanks! I guess that's what I get for not having looked at the car in a few years. :?
Posted: Thu Sep 30, 2010 5:11 am
by roelbest
Yes, I would also like to know if the can is really necessary. I'll put mine back for appearance, but I have no idea it it ever worked n the past 10 years!
