dash lights pulse
Posted: Fri Apr 02, 2010 9:29 pm
by 71runnerm51
Out driving last night and I noticed the dash lights pulse, I checked the volt gauge seemed normal , It was intermitant ... of course they always get brighter the faster you go !!! loose wire? :help:
Re: dash lights pulse
Posted: Sat Apr 03, 2010 12:55 pm
by moparite
Check the rheostat. They get dirty and don't always work well.
Posted: Wed May 05, 2010 11:36 am
by JosephGiannini
check your load draw to the lights the fusable link and the switch itself sounds likea amperage problem that is causing the lights to dim. if everthing is fine calculate total electrical usage amd make sure you are running the correct alternator for your needs and regulator.
