Challenge for the smart people
- NCbluebird
LOL now that I have your interest.......
I want to tuck my rear tires into the fenders and keep the fatties I have. Part of the problem is the previous owner put American Racing Outlaw II milled 15" wheels on but with incorrect backspacing on the rear, hence they stick out a bit and the rear was lifted, first with Gabriels and then one stopped working, instead of fixing or replacing they stuck a set of coils ontop of the rear end to the frame, crazy I know.
Well I bought a new set of Gabriel Air shocks to install, I want to get rid of the coils and I'd like to bring the rear down a bit, but don't want to buy all new wheels. I'm currently running 275/60 -15 , they're brand new. What I need is to see if anyone can locate a pair of American Racing Outlaw II milled wheels that will fit right and let me tuck those tires inside the fender so I can bring it down a bit
Anyone up for the challenge???
lol
lol
Re: Challenge for the smart people
are some rear ends narrower? maybe grab one of those? now you're buying a rear end, not a set of wheels...
Can someone chime in with drum to drum measurements, on what I presume is an 8 3/4 rear?
- My Cars: 1972 Roadrunner
From what I have been told by different tire professionals 275 tires need atleast a 9" rim (atleast for 17" rim with 40 series tires). If that same holds true for the 15" rim then you would have to step up to a 10" wide since they don't make a 15x9 in that style. The problem with the 10" wide is the offset is -38 and a couple of sites say that is too much. So I would maybe try talking to someone at American Racing or some retailer that has some experience with our older cars. Now I just saw that the only backspacing available on the 15x8 is 3.75" I dont think that will be enough to get them to tuck under, probably what you have on there right now. I hate to say it but from the 30 min I just spent looking (not very long so maybe I am wrong)I don't think it is going to work with those rims. The more I look the 15x10 only have 4" BS and I dont know if that will be enough either.
- NCbluebird
yeah I think honestly I'm going to be stuck finding another set of rims altogether. Hopefully I can use the tires, they're brand new
So, how about this, what recommendations from the site do I get for a Petty Blue with black strobes RR for wheels and keeping in mind I'd like to move the current tires within the fenders. Torq Thrust II with black centers, polished rim? Polished Torqs? or something completely diff.
72RDRNR wrote:From what I have been told by different tire professionals 275 tires need atleast a 9" rim (atleast for 17" rim with 40 series tires). If that same holds true for the 15" rim then you would have to step up to a 10" wide since they don't make a 15x9 in that style. The problem with the 10" wide is the offset is -38 and a couple of sites say that is too much. So I would maybe try talking to someone at American Racing or some retailer that has some experience with our older cars. Now I just saw that the only backspacing available on the 15x8 is 3.75" I dont think that will be enough to get them to tuck under, probably what you have on there right now. I hate to say it but from the 30 min I just spent looking (not very long so maybe I am wrong)I don't think it is going to work with those rims. The more I look the 15x10 only have 4" BS and I dont know if that will be enough either.
mmmmmmmmmm i have on my 71 gtx 275 60 15 on 15 x 7 ralley wheels so why do i need a 9 rim for 275 60 15
- NCbluebird
Ok another question while contemplating a new set of wheels and tires.
I have confirmed with talking to American Racing that I cannot get a set of Outlaw II wheels in 15x8 or 7 with more than 4" backspacing, so my original intention of just replacing the rear wheels with one of greater backspacing is not gonna happen. I will need to do a full 4 wheel replacement. But I do want to stay with the 15" so I can re-use my current tires.
Since I'm running 275-60x15 in the rear I was thinking a 15x8 with 4.5 backspacing, what about the offset????
and up front presents another query, currently I am seeing people say to use 15x7 with 3.75" backspacing, but is that with drums up front or discs? I have drums now and will be installing a disc kit in a couple weeks, does that change the backspacing consideration? and what offset?
I'm looking at some cragar SS wheels for the period correct look. But I certainly could be pursueded to look at some BOSS 338 in 17s or 18s as well <wink wink>
B
B
the new cragar eliminators!! they're stunning and 160 bucks a pop for 17's. eventually that's the way I'm going...gonna enjoy my police rallyes for now.
you could get a spring relocation kit. on my 72 ive got 15x10 weld prostars with mickey thompson 29x12.5x15 tires and they tuck up under the rear wheelwells really nice.just a thought
,jeff
The correct rear end for our cars is 2 inches wider than other B-bodys it is an E-body rear end width. You could do that, an A-body is even narrower but very rare.
a e-body is 60 ins a 71-74 b-body 62 insElvad wrote:The correct rear end for our cars is 2 inches wider than other B-bodys it is an E-body rear end width. You could do that, an A-body is even narrower but very rare.
I guess the same does not hold true for the 60 series tires, BFG reccomend a 7.5-9.5" rim. So I guess a better response would have been to check out the tire mfg site and see what they reccomend. Not knowing what tires you have I just went to BFG and found this for an example. Most of the tire mfg sites I have seen have similar info.71440 gtx wrote:72RDRNR wrote:From what I have been told by different tire professionals 275 tires need atleast a 9" rim (atleast for 17" rim with 40 series tires). If that same holds true for the 15" rim ...
http://www.bfgoodrichtires.com/specs/radial-t-a/12.html
- NCbluebird
So I was able to locate a matching set of American Racing Outlaw II wheels to match the front set in
16x8 5-4.5 bolt 0 offset and 4.5" backspacing
So I would need to also pick up a set of 16in tires, should I stick with the 275-60 series or what? This backspacing should get me inside the fender with the 275-50 size, would 295-50s put me back outside the fender?
Bill
Bill
I will go out and measure mine this weekend for you. I will see how much backspacing I have and how much room on each side of tire. I will also see what my tread/sidewall widths are.
- NCbluebird
ok will a wheel with these specs fit inside the fenders???
Tire - 275-60R15
15x8 5/4.5
-5mm Offset,
4.25" Backspace
I've got a line on an excellent price, was going to pick up two of these for the back and the front will get:
Tire - 235-60R15
15x7 5/4.5
-6mm Offset,
3.75" Backspace
But I need to be sure they will tuck inside
Bill
Tire - 275-60R15
15x8 5/4.5
-5mm Offset,
4.25" Backspace
Tire - 235-60R15
15x7 5/4.5
-6mm Offset,
3.75" Backspace
Bill
Just got mine measured:
My rim is a 17x9 with 5" backspacing. Don't know offset
Tires are 275/40 --- sidewall to sidewall it is just about 11" wide.
Outside of tire just clears the lip on quarters, inside there is 1 3/4" between tire and leafs.
Will yours fit?? I am thinking it will. But I would see what some of these others say (ie...71440GTX)
that have the smaller rims and larger sidewalls. Just from the rim measurements you will have little less rim on the outside than I do and that will be good.
