71/72 Dash wire harness
NCbluebird
Post by NCbluebird » Fri Oct 16, 2009 4:26 pm
Forgive the dense question please...
does someone make a new dash harness for these cars? I ask because my bird's wiring bahind the dash is a nightmare, looks like multiple splices all over the place during the years, I have no dash lights and gremlin's like, turn turnsignal on and radio goes off, no blinking just stready lights. But looking under the dash it's a wiring nightmare
pettyblue72
Re: 71/72 Dash wire harness
Post by pettyblue72 » Fri Oct 16, 2009 5:55 pm
Which year harness do you need, 71 or 72? 71 is a 1 year only and 72-73 are the same. There is a 72-73 harness for sale in the Parts for sale section of this site. The seller wants $180.00 for it along with a rallye cluster.
Joe
NCbluebird
Post by NCbluebird » Fri Oct 16, 2009 6:58 pm
I didn't know the 71 was diff, thanks. I have a 71, so thats what I'll need to hunt down
Elvad
Post by Elvad » Sat Oct 17, 2009 7:32 pm
As long as it doesn't start playing oldies and lock you in...I have a '71 dash I haven't looked at in 20 years, I know it has some of the harness. I may go over there tomorrow (Sun) If not I'll post some pictures as soon as I do.
HeavyMetal1971
Post by HeavyMetal1971 » Tue Oct 20, 2009 12:43 pm
66-74 Wiring Harnesses - Customs Available...
Bill & Rose Evans 814.864.2622, 8835 Parson Road, Erie, PA. 16509
Website: http://evanswiring.tripod.com
I have a 71 Satty which needed all the harnesses redone. My Mechanic and friend suggested I give them a call. I checked on the website to see what he's got. Wasn't positive if he would have something exactly the way I needed it, so I gave him a call and he knew right away what I needed and had it put together and in the mail the same day. Have dealt with him on 3 occasions now and know a few other folks who've had the pleasure of doing business with them. I recommend Bill Evans because he's been square dealin' with me. Hope you find what you need. ~laurie :wink:
PS - Right in the neighborhood of 115 S&H incld
Last edited by HeavyMetal1971 on Tue Oct 20, 2009 5:22 pm, edited 1 time in total.
Post by bruce » Tue Oct 20, 2009 12:47 pm
Evans did the engine harness on my Runner. I'm happy with it, and it sure beats taking the Year One beating on price. Be forewarned, a new dash harness is gonna be EXPENSIVE.
Post by CtownRunner » Tue Oct 20, 2009 8:46 pm
Evans does not make dash harness. Too bad. I wish they did too.
1968 Charger B5
Post by 1968 Charger B5 » Tue Oct 20, 2009 10:09 pm
I installed a 71 charger hidden headlight dash harness in my 74 roadrunner after i conerted to ralleye dash, and mated it to my original 74 non ralleye harness in the engine bay, just pulled and repluged the bulkhead to match it up, only differene i found were the run ignition (brown and blue) wires were reversed...i thought painless had a kit they made for the cars...?
1968 Charger R/T
1971 Plymouth Roadrunner
1998 Jeep Cherokee
2018 Jeep GC Limited
Elvad
Post by Elvad » Fri Oct 23, 2009 9:01 pm
I looked at the 71 dash i have and it has a replaced/melted wire right thru the dash/firewall harness and a bunch of scotch locks underneath. It makes me wonder if the 71's were problematic i don't think you want this one either...
Post by landon1 » Sat Oct 24, 2009 6:18 pm
may be a bigger task than you want, but i just finished re-wiring my entire car with a rebel wire harness. i have probably 30 hours or so in it including breaks for suppers and clean-up. it was a chore, but i am much happier now knowing my car isn't going to suffer another electrical fire. mine does have custom/aftermarket pieces, but i'm sure it wouldn't be bad just putting your factory ends on the new harness to connect under dash, etc. just another option - or, you can get a bit of wire and replace the bad wires where needed - that's what i've been fighting for years now, but i've had 2 electrical fires (starter relay fusible link didn't go, caught harness on fire while on interstate....then, the wire from ammeter to alternator burned up, catching the harness on fire under hood), the wiring under dash was hacked-on pretty good, and after the rebuild, i had to keep the car hot-wired as the whole harness just wouldn't get power for some reason
