Frame specs for 71
Posted: Sat Aug 22, 2009 5:17 pm
by Elvad
I was able to rummage through a cabinet of old frame books at a customers body shop and found this. Hope some of you guys can use this. My 72 has a solid k-frame, it is an early 72. Later about mid-year they changed to the huge rubber mount isolater type with the rubber around the rear springs too. I don't think these specs are good for those later cars. If this is too small PM me and I'll send you the one I scanned (too big to upload here)
Re: Frame specs for 71
Posted: Sat Aug 22, 2009 11:34 pm
by scotts74birds
Hey Elvad, this is almost too perfect. I have a 74 that was rolled and I need to replace the roof. These measurements would be perfect. They are close enough that I'm sure they can be of use to me. should I pm you my email?
Posted: Sun Aug 23, 2009 4:58 am
by 71440 gtx
Elvad wrote:I was able to rummage through a cabinet of old frame books at a customers body shop and found this. Hope some of you guys can use this. My 72 has a solid k-frame, it is an early 72. Later about mid-year they changed to the huge rubber mount isolater type with the rubber around the rear springs too. I don't think these specs are good for those later cars. If this is too small PM me and I'll send you the one I scanned (too big to upload here)
:rant: not on the 1972 b-body july 1971 - july 1972
1973 1974 b-body changed to the huge rubber mount isolater :beer:
Frame specs for 74
Posted: Sun Aug 23, 2009 2:38 pm
by Lrdrunner
I have a book for 74 with the same info. If you need info, e-mail me and I will scan and send it to you. I will need your e-mail address.
Posted: Tue Aug 25, 2009 1:13 pm
by SureGrip
I also believe that the FSM has those measurements in the Chassis Book. I have both the Body and Chassis Factory Service Manual for the '71 Plymouth.
Posted: Fri Sep 04, 2009 3:05 pm
by 1971RR340
If my PM didn't go through, I would definitely appreciate a set of factory specs. For those interested, I took some underhood measurments from a 71 GTX, same owner since 73 that he states was never wrecked. Not to be sacriligous but couldn't find the preferred tram gauge, had to use metric measurements. Email me at FishHawk210WA@gmail.com and I can fax or try to scan and email.
