Max Rear Tire Size
72RARBIRD
Max Rear Tire Size
Any recommendations of max tire/rim combinations. Has anyone mounted a 275/60/15 on a 15X8, 4-1/2 backspaced rim? I'm concerned with the increased section width of the 15X8 versus 15X7.
Rear Tire size OK
I have 275/60 x15 on Mirada wheels that are 4.5in backspaced and 8in Wide, they fit very well. I have at least an inch to clear the rear spings and more to the inner edge of the wheel well lip.
CtownRunner (Cleveland)
Chris
Chris
Front Tires
Fronts are 235/70x15 on same wheels. Keeps the rolling diameter the same. Almost went with this on all 4 but the 60's in back give this style car nicer lines. I have air shocks in back (they came on the car) for just a little lift but not needed for the tires to fit. Just a little nose down attitude and T bar adjustment. I think I will play with a little less air in the rear soon.
Chris
Chris
- Dave
FWIW, I'm running a 4.75" backspace on an 8" rim. That perfectly centers the rim in the wheelhouse. Here are a couple pictures of the "test fit" of the Road Runner's rims with the 295-50-15's on the Sebring Plus
It's dead on 3/4" clearance to the spring.
I run 255/60/15's on 15X8 ( 0 offset) on all four corners. I know I can get a 295 on the rear, as we have seen- but the 255 is about the biggest for the front and not have interference when the wheels are fully turned.
- Dave
Ah cool. My "math" said I might have a slight rub at full turn on the fronts with the 245-60's on the 15x7's, but I wasn't 100% sure about that. I'm guessing that if your 255's clear, my 245's should be fine. That's great news!
Ya I run a 1.00" T bar up front so the suspension isn't squishing around. I have @ 1/2" clearance to the sheet metal as the wheel goes through it's arc and @ 5/8" from the frame at lock. The 245's will be no problem
