Page 1 of 3
What carbs came on 71' roadrunners?
Posted: Sat Jul 18, 2009 7:25 pm
by pats71
Anyone know what the cfm rating and what kind of carbs came on 383HP motors in 1971?
Re: What carbs came on 71' roadrunners?
Posted: Sat Jul 18, 2009 8:59 pm
by 71440 gtx
a carter avs 6.25 cfm and 600 cfm holley on the 383 4bbl
carter avs 6125
and 1355 cfm holleys on 440 6bbl and 2 afb ca rters on 426 hemi :lol: :beer:
Posted: Sun Jul 19, 2009 9:10 am
by landon1
i was thinking a 625 AVS, guys on moparts thought a 4160 holley (585-600 cfm) - that's actually what someone had on my 440 when i got it.
it probably breaks down even further to what transmission, california spec or not, and then probably to if it was a dual/single point, etc. etc.
Posted: Sun Jul 19, 2009 12:06 pm
by pats71
I think your the same landon1 as the one over on moparts right?
Posted: Sun Jul 19, 2009 2:43 pm
by landon1
indeed, makes it simple when it comes to remembering usernames :beer:
Posted: Sun Jul 19, 2009 4:13 pm
by Eric
You need to be more specific if you want part numbers. Auto or manual trans? Air grabber or not? There were different part numbers for each, but all 71 383 runners would have Holley carbs.
Posted: Sun Jul 19, 2009 5:25 pm
by JosephGiannini
1971 383 came with 2 BARREL CARTER BBD MANUAL TRANS MODEL NUMBER 4961S
AUTO TRANS MODEL NUMBER 4962S
1971 383 came with 4 BARREL HOLLEY MODEL 4160 WITH MANUAL TRANS MODEL NUMBER R6191A
R6193A+
AUTO TRANS MODEL NUMBER R4668A
R4739A+
Posted: Sun Jul 19, 2009 7:30 pm
by pats71
Sorry I forgot to be more specific. Manual trans, four barrel, and air conditioning. Thanks for the numbers there Joseph. :beer:
Posted: Mon Jul 20, 2009 9:02 am
by 71440 gtx
Quote:
Quote:
All '71 383 4bbls were HOLLEY equipped.
on the moparts
I have to disagree. My 1971 Charger came stock with the 383 4-bbl and it had a Carter AVS. This is also an A/C car.
6125s - 625cfm - Came on my 71 Superbee 383 Auto - No air , no ramcharger hood
Have the broadcast sheet
Posted: Mon Jul 20, 2009 3:01 pm
by pats71
I go between moparts and the nest to see if there is consistency in the information. I think the nest is the better of the two depending on what your car is. Sometimes moparts gets frustrating cause you get a lot of the aerogant types who refuse to listen to anyones input.
Concerning the carbs, it seems like cars with and w/o Air conditioning could have come with either holley or carter avs. The deciding factor, from what I'm seeing, is what type of transmission the car came with. I've got a 4 speed so more than likely it probably had a holley. I don't have the factory carb but a lot of guys are saying that they were 600-650cfm? I'm going to have to find a re-pop one, mopar performance is makin'em, and I'll probably go with a 750cfm. 600cfm just seems really small for a big block.
Posted: Mon Jul 20, 2009 4:40 pm
by Serious Satellite
Personally, I'm on a low carb diet, so I couldn't answer this question if I wanted too. Too fattening. :P
Posted: Tue Jul 21, 2009 7:04 am
by 71440 gtx
you do not need a 71factory carb
you put can on any year 64- 78 factory carbs
a holley or avs or afb on 383 :beer:
Posted: Tue Jul 21, 2009 7:58 pm
by Eric
Ok, if you're not looking for a factory part numbers correct carb, just the correct style, you'd want the Holley 4160 series.
Posted: Tue Jul 21, 2009 11:07 pm
by pats71
Alright thanks eric. I'm looking at going with a 750cfm version. I just plan on putting in a cam close to hemi cam specs and the rest of the motor will remain stock. Does anyone think this might be too much carb? Which would be a better holley carb, vacuum secondaries or double pumper?
Posted: Thu Jul 23, 2009 4:35 pm
by rt-man
Pat, I used to be a big poster on Moparts, have settled down since I stopped/don't chase the factory-correct resto bug anymore. Straight up, send a private note (PM) to Streetwize over on Moparts. He'll help you out Big Time with matching fuel/air, intake, cam and exhaust. Mismatched stuff is a bear to sort out and your car will run like crap.
my 2cents: either do it factory stock with ALL factory parts, or seek our Streetwize.
