fiberglass repair?????????
73sunroofSSP
Post by 73sunroofSSP » Sat Jun 07, 2008 3:28 pm
Should I just reapply resin to these areas or put down a new layer of glass and resin over it?
Minor damage due to the fire.
fiberglass repair
Post by rr6pak » Sat Jun 07, 2008 4:21 pm
Where is this damage at, '72Bird? I would first use some sand paper to scuff it up. 2. Use some alcohol(Isopropyl, NOT drinking, LOL) to clean. Depending on the damage (cant see what is really damaged) might have to put some resin and glass down. Just my 2 cents :D
73sunroofSSP
Post by 73sunroofSSP » Sat Jun 07, 2008 4:34 pm
inside the hood scoop won't be seen once i do the isolator plate and cut the hole and mount the seal.
Post by Smellslike1974 » Sat Jun 07, 2008 4:42 pm
From the pics it looks like the fibers are separated almost frayed,im pretty sure all you need to do is apply resin to glue them together again.But i would ask some one who does this.
fiberglass
Post by rr6pak » Sat Jun 07, 2008 6:23 pm
72bird wrote:inside the hood scoop won't be seen once i do the isolator plate and cut the hole and mount the seal.
I would scuff the area up before you apply resin though. P.S. make sure it is clean as well :D
73sunroofSSP
Re: fiberglass
Post by 73sunroofSSP » Tue Jun 10, 2008 7:58 pm
Thanks the repair came out perfect. Now to design and mount the isolator plate to use the air grabber baseplate. Can't use a modified SixPak base due to the 2 spd wiper motor.
Post by Smellslike1974 » Tue Jun 10, 2008 8:07 pm
Thats great everytying worked out for ya.
:beer:
make sure to post pics when your hood system is setup :D
73sunroofSSP
Post by 73sunroofSSP » Tue Jun 10, 2008 8:51 pm
No problem the pics will be in the diary in gen disc.
