71
71
Post by 71440 gtx » Thu May 22, 2008 12:52 pm
Can anyone help. It reads as follows
3461135
73608
063-1-A
C-4601-AB
Out of a 71 B body
Post by Smellslike1974 » Thu May 22, 2008 12:56 pm
Where is this tag located?
Post by Eric » Thu May 22, 2008 1:04 pm
Looks like the brake booster
Post by 71440 gtx » Thu May 22, 2008 1:04 pm
its on thebrake booster :beer:
Post by Eric » Thu May 22, 2008 7:10 pm
Ok, here's a little
3461135 - Chrysler part number (although I don't see this as a listed part number in the Lightningjar database)
73608 - sorry, don't know this
063-1-A could be the date code (I'm not up to speed on the date coding for these)
C-4601-AB Midland Ross part number
I can tell you the Chrysler part number is different on my original 383 auto disc brake car
general
Post by general » Thu May 22, 2008 7:21 pm
Eric, where are you getting the part number from off your booster.? Tag?
What is your part number? I find similar numbers in my parts book but not this one. Its close but no match.
Date code I'm guessing 063 being the day of the year, the one is 1971, the A stumps me.
Norm
Post by Eric » Fri May 23, 2008 12:49 pm
Norm
Yes, I'm looking at my tag for the part number. I thought my booster was original to the car, but the part number on mine does not correspond with numbers listed in the parts book either (although very close). Also, mine wouldn't seem to be correct if the date coding is as you believe (that line on mine is 120-2-G....so I'm a little confused by this.
general
Post by general » Fri May 23, 2008 1:45 pm
Eric what is the part number on yours? Do you have disk or drum? On the rear you must have the 10" drums right?
We need to get a 1972 parts book and see if these numbers are in that book. I have the 70/71 and the 3461135 is not there also, altough like yours its close.
Post by Eric » Sat May 24, 2008 1:25 am
Mine is 3461264, also not listed in the Lightningjar database....on my 383 auto disc car. The other car doesn't have the original booster. Maybe the numbers stamped on the tags didn't match the listed part numbers. I'm going to have to do a little more research on this one.
