Bellhousing
Posted: Thu May 08, 2008 10:21 pm
by mopar71
Where on the bellhousing is the casting number stamped? I dont see it anywhere on mine,and I have to get a dust cover but they want to know what casting number you have.
Re: Bellhousing
Posted: Thu May 08, 2008 11:02 pm
by 71440 gtx
mopar71 wrote:Where on the bellhousing is the casting number stamped? I dont see it anywhere on mine,and I have to get a dust cover but they want to know what casting number you have.
IS ON BACK OF BELL HOUSING PASS SIDE 511 512
Posted: Thu May 08, 2008 11:50 pm
by mopar71
I will look tomorrow,Thanks
Posted: Fri May 09, 2008 12:13 am
by 72RoadRunnerGTX
Numbers are cast into the transmission mating surface. I believe the correct number should be 2892513.
Posted: Sat May 10, 2008 6:47 am
by 71440 gtx
72RoadRunnerGTX wrote:Numbers are cast into the transmission mating surface. I believe the correct number should be 2892513.
that
that is number
Posted: Sat May 10, 2008 9:28 am
by mopar71
so the number is sandwiched between the bellhousing and the trans? I have mine put together!
Posted: Sat May 10, 2008 12:50 pm
by 72RoadRunnerGTX
With the transmission in place you won’t be able to see the number. If the bell housing is original to your car it should be the aluminum “513†version. There were older cast iron big block housings used for the 130 tooth (10 ½†clutch) and 143 tooth (11†clutch) flywheels. Each had a slightly different sized inspection cover. By 1970 all big blocks used the same aluminum “513†housing. Year One sells a steel reproduction inspection cover under the number BHC105. I have seen plastic reproductions available too, however not recommended.
Posted: Sat May 10, 2008 1:48 pm
by mopar71
Thanks for the info,I dont know if it is original or not,the trans was not original to the car,I might seperate them to take a look.
Posted: Sat May 10, 2008 5:30 pm
by 72RoadRunnerGTX
What’s it made of? Cast iron or aluminum? If it’s aluminum then it’s a “513â€. If it’s cast iron then only way to know for sure would be to look at the casting number.
Posted: Mon May 12, 2008 7:48 am
by mopar71
Posted: Mon May 12, 2008 1:27 pm
by 72RoadRunnerGTX
Looks like a "2892513" to me.
Posted: Mon May 12, 2008 8:42 pm
by mopar71
Thanks for the help
