Voltage limiter
- mopar71
- My Cars: 1971 roadrunner
Voltage limiter
I am putting my gauges together and wanted to replace the Voltage limiter,is anybody making an electronic conversion or do I have to get the parts and solder them myself? I thought Dave or someone else had a site that was doing this.any help appreciated.
There are some postings here from last year that contain the info you seek. Since that time I have completed my own limiter mod. Was able to fit the 7805 and caps inside the original limiter housing. I pop riveted the 7805 to the inside of the housing, using the housing and the cluster as my heat sink.
- mopar71
The one for the gas and temp,gauges.landon1 wrote:you're talking the instrument voltage regulator??? i thought you could get re-pops from paddock and other suppliers?
yes you can get them from those places,but I want to upgrade to newer electronics,also you dont have to worry about a voltage spike damaging your gauges.
The company is Real Time Engineering. They do a lot of mopar dash stuff. The limiters are solid state, MUCH better than original.
Here's the link
http://rt-eng.com/mediawiki/index.php/RTE_limiter
Here's the link
- rr6pak
- My Cars: 1971 Tor-Red RR
limiter
Has anyone used the Real Time Engineering Limiters? Any trouble with putting one in? They advertise that it is a replacement for Mopar P/N 2258413. I think the P/N is 2985707 for the 71 B-bodies. Just wanted to get it clearified.
