73X
Post
by 73X » Fri Apr 11, 2008 4:56 pm
Anyone know if the quarter panel extensions and wheel houses for 73 and 74 4 door Satellites are the same for 73 - 74 Road Runners? I know 68 - 70 B Body 2 and 4 door pieces are the same.
Post
by Eric » Fri Apr 11, 2008 7:51 pm
can't say for sure, but I seriously doubt it.....71-72 2dr and 4dr sheetmetal is completely different
Serious Satellite
Post
by Serious Satellite » Fri Apr 11, 2008 10:11 pm
Not only that but the base length of the four door is a bit longer than the two door. . .
73X
Post
by 73X » Sat Apr 12, 2008 12:40 am
Thanks Guys,
Hope they make sone new sheetmetal soon for these cars. I have some pieces off of a 74 Sundance I parted out last year, I will have to see if I can make them work.
Post
by 71440 gtx » Sat Apr 12, 2008 1:26 pm
the wheel houses are the same 71 -74 two door or 4 door
not the extensions or framed rails too long for the 2doors
73X
Post
by 73X » Sat Apr 12, 2008 4:40 pm
I found a 4 door that is in pretty good shape, I will cut the wheelhouses out of it. Thanks for the info.
moparmarks
Post
by moparmarks » Sat Apr 12, 2008 9:32 pm
71440 gtx wrote:the wheel houses are the same 71 -74 two door or 4 door
Inner wheel housings are the same for 71-4. Four different outters though. 71/2 Ply, 73/4 Ply, 71/2 Dodge and 73/4 Dodge.
Southwestern Sheet Metal
71-4 B-body
73X
Post
by 73X » Sun Apr 13, 2008 9:20 pm
so will the 73 outer 4 door ply, work on a 73 ply 2 door?
Post
by landon1 » Sun Apr 13, 2008 10:18 pm
i don't think i've ever seen a 4 door other than 71 lol.....um, i believe i read that on 71s at least, you can use the drivers front fender to patch the passenger quarter and opposite for other side if that would help....
