suspension torque values
Posted: Wed Mar 26, 2008 9:25 pm
by birdbrain
i'm betting somebody has a 73 FSM here and can give me the torque specs for the torsion bar crossmember mount bolts, K frame bolts, upper control arm pivot nuts, upper and lower ball joint nuts and tie rod / idler arm / pitman arm nuts........your help would be much appreciated. i got everthing from just suspension, but i got rubber control arm bushings and polygraphite K frame and torsion bar crossmember bushings. according to the included paperwork i am to use the factory torque specs on the PG bushings and retorque them after some road time. supposedly the PG bushings in the K and torsion members will stiffen this baby up a little without destroying the ride quality.......here's hoping!
Posted: Thu Mar 27, 2008 1:45 pm
by 71_DEPUTY
OK- OUT OF A 74 MANUAL- SHOULD BE THE SAME
torsion bar crossmember mount bolts--75 foot pounds
K frame bolts--50 foot pounds
upper control arm pivot nuts--75 foot pounds
upper and lower ball joint nuts--upper-125ft bottom-85ft
tie rod--- 132 inch pounds
pitman arm nuts--175 inch pounds
john mac
Posted: Thu Mar 27, 2008 7:03 pm
by birdbrain
i much appreciate the info john mac! now i can put this beast back rollin' this weekend.
Posted: Fri Mar 28, 2008 7:43 am
by 71_DEPUTY
welcome!
Re: suspension torque values
Posted: Thu Jun 11, 2020 8:55 pm
by patrick
For the lower ball joint, is that the torque setting for the threaded or non-threaded? Mine came with threaded. Also, I hate how the factory manual has absolutely no picture of the floating torsion bar rear crossmember piece, but from the description in the manual (presuming it's referring to the same piece), it does state 75 ft. lbs. as the other gentleman stated. I'm using solid bushings, but I presume the torque is the same...
