Pollution Canister
beepx2
Pollution Canister
Post by beepx2 » Mon Feb 18, 2008 1:01 pm
My canister is located up inside my left rear quarter panel. Seems to be factory mounted. Sometimes I have fuel leaking out from it. I think I have the vent hose conncted correctly. The fuel tank is not leaking. It's a mystery to me. Any ideas?
Thanks,
Bill
Post by Eric » Mon Feb 18, 2008 1:22 pm
If you take off the metal shields (there are two of them), you'll see 4 rubber gas lines running to it. Chances are if they're original they have cracked from age and that's where you're getting leaks....may be cracked up farther were you can't easily see it.....
Post by bruce » Mon Feb 18, 2008 1:26 pm
Yep, just as Eric says... I've replaced all those rubber lines on my car too, because they leaked.
Post by Eric » Mon Feb 18, 2008 1:27 pm
Especially if you completely fill the tank ..... DAMHIK :mad:
beepx2
Post by beepx2 » Mon Feb 18, 2008 5:04 pm
Thanks guys. I do smell gas when I fill the tank and could not find the source. Those lines must be leaking. I'll check and get back to you. Is that usaul that the canister is located back there?
Thanks,
Bill
Post by bruce » Mon Feb 18, 2008 5:05 pm
Yep, that's on all '71s... and leaks on all of them too I'm sure!
Post by Eric » Mon Feb 18, 2008 7:19 pm
Should only be a problem when you overfill the tank, as those lines come off the top front of the tank IIRC.
Post by 72RoadRunnerGTX » Mon Feb 18, 2008 8:19 pm
FYI, the vapor separator was redesigned and moved to a location directly above the deferential mid year 72. Beginning about April production 72 thru 74 the fuel tank vent nipples for the separator are located on the front upper edge of the tank. Factory must have identified a problem pretty early on.
Post by mopar71 » Tue Feb 19, 2008 12:55 am
Thanks for the heads up guys! :beer:
roelbest
all matching
Post by roelbest » Wed Feb 20, 2008 4:44 pm
That cannister looks great, is it a metal colour or more a white colour?
thanks
