Need rocker panel trim clips - anyone know a source?
JimF
Post by JimF » Wed Dec 12, 2007 8:24 pm
I have a 1971 Satellite and it's about 99.9% restored. The last thing it needs is for me to attach the rocker panel chrome trim (the thin 6' strips), but I can't seem to find the plastic clips that allow the trim piece to attach to the small metal tabs in the body.
I've attached a picture of the car and the metal tabs just over the rocker panel. Has anyone had any luck in finding these pieces?
Thanks.
- Jim
(194.53 KiB) Downloaded 1922 times
JimF
Post by JimF » Tue Dec 18, 2007 4:45 pm
Update:
I've contacted Mr. G's but they just have clips and fasteners and no idea at all what year or model car they are used for.
If anyone here has a sample clip/fastener for these rocker panel moldings I'd be very very appreciative. Any pictures or even a description?
Anyone? Anyone?
- Jim
luvmoparz
Post by luvmoparz » Tue Dec 18, 2007 5:11 pm
Here is a pic....very blurry but best I can do.
I'll have you know, I went out and yanked it off.....I figure its gotta come off when I replace fenders anyway.
it has W.F. on it and right under the wf is 12
Thats the only writing on it.
In the avueco catalog...on their main page, the clip there looks close.
http://www.auveco.com/product/auto.html
Also, page 400 item 12594 looks close
page 457 item 11354 may work, have to get sizes
this clip is 9/16" wide measured by the tips of the 4 little wings (you can only see 3 in my shitty picture because one was bent.
the main body of the clip is 3/8" wide
end to end measures 1 inch exactly
the hole that would actually hold clip on to peg is dead center, with the slide on hole off-set to one side horizontally.
There is a notch in each end measured 1/16" X 3/16"
1972 440 Roadrunner/GTX
JimF
Post by JimF » Wed Dec 19, 2007 3:13 pm
Thank you! Even the blurry picture will help. And thanks also for the detailed desription.
By the way, here's more on my car if you're interested:
http://episteme.arstechnica.com/eve/for ... 8006513831
- Jim
JimF
Post by JimF » Wed Dec 19, 2007 3:29 pm
luvmoparz,
One more question:
Did your car have the thick side moulding or the thin? The picture of the green car in your autosig shows the thicker moulding, which is different than mine.
Thanks.
- Jim
luvmoparz
Post by luvmoparz » Wed Dec 19, 2007 5:00 pm
Thin....same on both of my 71's
JimF
Post by JimF » Sun Dec 23, 2007 5:35 am
Thanks. I'm looking at Mr. G's for something close.
- Jim
