71-72 Road Runner Rear Swaybar Pics
Posted: Thu Sep 27, 2007 9:51 pm
by Ronnman
Can some one post some pics showing how the original rear swaybar is connected to the rearend? I know that there are brackets that bolt to the rear frame rail in front of the rearend. But I don't know how the rest is setup.
Thanks,
Ron
Re: 71-72 Road Runner Rear Swaybar Pics
Posted: Fri Sep 28, 2007 11:31 am
by fourforty6pac
Ronnman wrote:Can some one post some pics showing how the original rear swaybar is connected to the rearend? I know that there are brackets that bolt to the rear frame rail in front of the rearend. But I don't know how the rest is setup.
Thanks,
Ron
There is a plate that mounts with the shock plate and is held on with the u bolts.
Posted: Fri Sep 28, 2007 8:21 pm
by Ronnman
Someone at Moparts sent in a scan of the layout. I thought that I would share it with you.
Ron
Posted: Fri Sep 28, 2007 8:34 pm
by 71440 gtx
but they do not come on a 71 b-body 72 -74 b-body only
Posted: Mon Oct 29, 2007 10:12 am
by 72Rdrnner
Deleted to save pix space
Rear sway bar (third pix)
Posted: Mon Oct 29, 2007 10:14 am
by 72Rdrnner
Posted: Mon Oct 29, 2007 3:18 pm
by CtownRunner
My god thats clean!
Posted: Mon Oct 29, 2007 5:15 pm
by 72Rdrnner
CtownRunner wrote:My god thats clean!
Yeah I kind of got carried away with powder coating. All the suspension, front and rear, drive shaft, gas tank, all engine accessory mounts, and a few other odds 'n ends. A bitch to keep clean though....especially since I put it back together to be driven and seen.
I get 1/2 off at the local Sonic when I drive it over for a meal! But I have to eat there not take it with me! I guess the manager is a Mopar guy!
Posted: Mon Oct 29, 2007 8:34 pm
by CtownRunner
Half of at Sonic not bad eye candy I guess. At least it will pay for itself in a few hundred or thousand or hundred thousand visits.
Posted: Sat Nov 10, 2007 1:07 pm
by 6o4o
that's a beautiful RR! I was already searching for that square rubber but had no luck! Thanks for the hint!
Posted: Sat Nov 10, 2007 1:51 pm
by 72Rdrnner
6o4o wrote:that's a beautiful RR! I was already searching for that square rubber but had no luck! Thanks for the hint!
Thanks...took a lot of time, not to mention a few bucks & beers!
If memory serves me right I got the square rubbers from Just Suspension. They are one piece and poly, vice rubber. I have a bill for a pair of something that cost $20 and I think that's what they were.
I originally thought about cutting a slit in them to put them on, but thought better about it and did it as I described.
