Hood Hinge
Posted: Sun Aug 05, 2007 9:17 am
by aerodynamic
Hey all, does anyone know of a place where hood hinges can be sent for repair? I think mine are bad. The hood sits up like half an inch (over the hinges) when it's closed,and the hinges do appear to be adjusted as far down as they'll go. If I push down on the rear part of the hood they'll sit level, but then they come up again after driving.
Input??
hood hinges
Posted: Sun Aug 05, 2007 11:50 am
by rr6pak
Check out:
www.smsmopar.com
They restore hinges, door hinges, e-brakes, heater boxes, and steering columns. Hope this helps
Posted: Sun Aug 05, 2007 8:00 pm
by aerodynamic
Thanks man, that will do nicely.
hinge
Posted: Sun Aug 05, 2007 9:37 pm
by scottish440
Whatthe heck is up with some of these hinges......i have 2 cars that the hoods are jacked up on....like on aerodynamic's car.
anyone pinpoint the problem with these hinges??
Posted: Mon Aug 06, 2007 6:43 am
by CtownRunner
Yeh, similar issue on my passenger side. It wants to lift up and inch or so unless I push down on it after I close the hood.
Seems like SMS does nice work but it seems $200 to rebuild them is a bit much for my budget. I need a cheap quick fix.
Posted: Tue Aug 07, 2007 12:57 am
by fourforty6pac
I've seen the rebuild kits on ebay from time to time, they go for about $35. Another option is to get a good used set of charger hinges and springs (stronger spring). Sets often sell for 20 -25.
Posted: Tue Aug 07, 2007 2:21 am
by gionni
thanx...i have the same problem with my hood....
they come up after driving!
here a picture on highway...
i will change my hood hinges...
Posted: Tue Aug 07, 2007 6:17 am
by mopar71
Dam that car looks awsome!
Posted: Tue Aug 07, 2007 6:26 am
by aerodynamic
I really thought I was the only one with this problem. Maybe we should start a support group, lol!
I couldn't help but notice the sh*t eating grin on the driver of the above b-body. It IS a great feeling isn't it?
Posted: Tue Aug 07, 2007 11:58 pm
by 73X
Have adjusted my 73 RR/GTX and my son's 71 Charger this way and worked great. Had the same problems you guys had. From Rick's Restorations
http://www.restorick.com/tech/topic.asp?TOPIC_ID=10
[quote]Before removing the hood hinges, it can be helpful to make alignment references with masking tape on the hood and fenders.
Also note the alignments to the fenders so you know what you have. With the fenders incorrectly aligned, the hood to fender gaps will not be parallel.
With a helper or 2, unbolt the hood from the hood hinges and remove.
Then remove the hinges from the inner fender.
For reinstalling, bolt the hood hinges to the inner fender at about midway in the vertical adjustment slots. Install the hood to the hinges.
Front to rear adjustments are on the hood side area of the hinges.
Up & down adjustments are on the inner fender area of the hinges.
Side to side movement is controlled by the latch positioning and fender side bumpers.
On rare occasions the side position has to "tweaked" by a push on the rear of the hood to the side, causing slight bending of the hinge arms.
The front height is controlled by the bump stop studs with the rubber caps.
A common alignment problem on E-body & 71-up B-bodies is with the rear hood edge being up too high with the hinges being adjusted all the way down on the inner fender.
This is an adjustment problem! Start by moving the hinge up on the inner fender. (yes, up!)
Then, loosen the 2 rear bolts and leave the front bolt snug. Now lift the hood to make the hinge rotate (as viewed from the side). Retighten the rear bolts and check the fit. This procedure will get that tail to come down. Adjust the front-to-rear dimension on the hood side bolts.
It can be frustrating and take some time, but these hoods will fit correctly! I’ve installed them with the hood sitting about 2 1/2" above the fender...using this method, the hood was fitting perfect in a few minutes!
Rick
[/quote]
Posted: Wed Aug 08, 2007 1:50 am
by mopar71
Rick, thanks for that information,
aerodynamic, I will see my therapist on friday, I think he said I have roadrunneritis, one of the symptoms is foamig out the mouth, he said to not look at roadrunners like gionni's for long periods of time.
Posted: Wed Aug 08, 2007 3:07 am
by gionni
Posted: Wed Aug 08, 2007 4:46 pm
by 73X
I'm not rick, it was from his site. Your welcome for the link.
Posted: Thu Aug 09, 2007 4:48 am
by gionni
uhh sorry!
