Ultimate Wiring Picture Guide 71 Plymouth / Dodge Bbody
My Cars: 71 roadrunner
Re: Ultimate Wiring Picture Guide 71 Plymouth / Dodge Bbody
Post by dangina » Thu Feb 11, 2016 1:17 pm
rr6pak wrote:
72RoadRunnerGTX wrote:Fairly easy conversion, done it many times, will need the conversion harness that comes with the kit, or can be purchased separately. Done correctly, can’t tell it wasn’t factory.
Doesn't YO sell a harness with the electronic conversion? I think it is basically the same harness. When I have the time, guess I'll have to check with them.
most of the harnesses posted in this thread are from YO! M&H sells direct to YO.
Post by rr6pak » Thu Feb 11, 2016 2:51 pm
Does anyone have a picture or two of where the dash grounds are? Mine's been apart waaaay to long :D
Post by 72RoadRunnerGTX » Thu Feb 11, 2016 4:06 pm
Lower right in this shot.Image
will need to save picture, then view.
Post by rr6pak » Thu Feb 11, 2016 4:27 pm
I see the ground. Is that a "J" clip or something that the screw screws into? Looks like some sort of sheet metal screw. Thanks
Post by 72RoadRunnerGTX » Thu Feb 11, 2016 11:12 pm
Yes and yes, with a large flat area Philips head.
72 cuda repli-mod
Post by 71_bronze_gtx » Mon Feb 22, 2016 5:34 pm
Interesting approach to the wiring harness problem - nothing is labeled. I took a different cut at it over the last year. I have the shop manuals for both 71 and 72. I bought the following harnesses for my 71 GTX with 4 BBL and electronic ignition:
Dash
Engine (modified for electronic ignition)
Forward lighting
Rear Lighting (This harness itself does not connect to much of the rear lighting except the left side marker. There is another harness that plugs into it and picks up the tail lighting and RH marker. Nobody seems to make that one.)
Anyway, using the electrical schematics I made a sort of drawing of each harness, and annotated them according to the notation used in the schematics, which gives wire number, wire gauge, and color. Mostly, I left out the gauge, unless it was large wire. They're color coded, and a key is included on the dash harness drawing.
The people who drew these schematics, especially the IP schematic, weren't overly concerned about making them easy to follow.
Myb drawings are multiple pages. I scanned them to create PDF files for each. Can't attach, but would be happy to send to anyone who wants them. PM me.
Also, if anyone needs any schematics for 71 or 72, PM me and I'll get it to you.
71-RM23
Post by 71-RM23 » Mon Jul 27, 2020 9:52 pm
Kind of reviving an old post but, has anyone found the rest of the rear lamp harness or who makes it? I have the M&H Rear Lamp Harness but can't find the brake lights, backup lights and right side marker light.
Post by dangina » Tue Oct 20, 2020 6:07 pm
So far I have been unable to find anyone that makes the harness you speak of :(
