Belt changing - need to pull PS or fan??
Your diagram makes no sense.How is the fan and water pump being driven?The alt. belt should go from the crank over the fan/waterpump pulley to the alt. pulley and back down to the crank.The belt should be on top of the fan pulley not under it!
The diagram isnt 3d!mopar71 wrote:Yes ,the power steering belt will go over the fan because it is in front of the crank pulley but the alternator one is stuck between the crank and fan pulleys! look closer at the diagram!Smellslike1974 wrote:Billzilla,is there anyway you can take a picture of your engine bay?
Going by the diagram to posted,if you loosen the altinator mount,loosen the power steering,the belts should be big enough to just wrap around the fan.
And if that was the case,what you say,removing the fan wouldn't make sense.
None of this makes sense.!
- mopar71
- My Cars: 1971 roadrunner
I just noticed that the diagram is wrong,the crank is what powers everything,so your water pump and power steering would never turn based on that diagram.The power steering should be on a belt by itself going to the crank,and the alternator and water pump should be together going to the crank.
Allow me to repeat:
I will try to get pics of the pullies. I just f*cked up my upper door panel trying to tighten up my door frame so I had to walk away from the car for a bit. It won't lock, now.billzilla wrote:OK, I was stupid with the diagram - the PS belt goes to the crank AND fan pulley, not just the fan as I show in the diagram. So the belt on the right is more of a triangle.
Still, though, I can't get the rear Alt belt off without yanking either the fan pulley or crank pulley entirely.
