Glove box
fourforty6pac
Post by fourforty6pac » Sun Jun 17, 2007 11:43 pm
72GY9Runner wrote:I'll try the steel wool, but I'm not just talking about the hinge area.
Most of the inside of the box is covered in rust stains. It almost looks like someone used it for a bolt bin at some point in its life.
Try some CLR on that rust.
Bird Brain
Post by Bird Brain » Fri Jan 04, 2008 7:33 pm
For my 2cents....
To the best of my knowledge the 71 I have now is original it appears somewhat aged if you know what I mean, and it is a milky semi-transparent white. My first 71 I bought back in 1979 was surely original and I'm certain it was the same milky semi-transparent white. However I too have seen black ones and I'm most certain that all the reops are being made off white.
fourforty6pac
Post by fourforty6pac » Tue Jan 15, 2008 9:32 pm
ROADRUNNER7169 wrote:you can use a fine steel wool to clean the rust marks off yours ( I had the same problem whare the hinge bolts on steel wool fixed me right up)
CLR works too.
roelbest
all matching
Post by roelbest » Wed Jan 16, 2008 3:38 pm
My '72, original, is white/translucent
Post by Eric » Wed Jan 16, 2008 5:06 pm
Bird Brain wrote:For my 2cents....
I would be curious to know the build dates on the two cars
general
Post by general » Wed Jan 16, 2008 7:21 pm
Well my RR was built May 71 and it has a white glove box liner.
