Radio Antenna
Radio Antenna
Post by 71bird » Sat Sep 15, 2018 12:11 pm
Does anyone have an original 71 antenna that is out of their car, that I could get a good picture of the base. I can't seem to get this repo attached to the fender right, maybe it's just not made right.
72 cuda repli-mod
Re: Radio Antenna
Post by 71_bronze_gtx » Fri Nov 02, 2018 10:40 am
It's been a while since you posted this question. Have you solved your problem yet? I'll have mine out within a couple days.
Re: Radio Antenna
Post by 71bird » Fri Nov 02, 2018 7:53 pm
No, I haven't. I was wanting to see an original, the part inside the fender to compare it to the repos. Thanks
72 cuda repli-mod
Re: Radio Antenna
Post by 71_bronze_gtx » Sun Nov 04, 2018 1:36 am
Sometime after I bought the car I discovered that the previous owner had hidden the antenna in the space behind the plastic splash guard. It was tied to the fender support and the bezel and nut were missing. I can't be certain that the base is original. When it's all assembled on the fender, the antenna leans slightly outward. This is determined by the bezel rather than the base. In the photos, the view is as seen from looking backward through the fender.
The attachment assembled reduced.jpg is no longer available
The attachment exploded straight on.jpg is no longer available
exploded on angle.jpg (41.5 KiB) Viewed 17356 times
72 cuda repli-mod
Re: Radio Antenna
Not sure why, but only letting me attach one pic at a time.
assembled reduced.jpg (38.37 KiB) Viewed 17356 times
72 cuda repli-mod
Re: Radio Antenna
Post by 71_bronze_gtx » Sun Nov 04, 2018 1:37 am
exploded straight on.jpg (28.22 KiB) Viewed 17356 times
72 cuda repli-mod
Re: Radio Antenna
Post by 71_bronze_gtx » Sun Nov 04, 2018 1:39 am
I believe I got the bezel and nut from Year One.
Re: Radio Antenna
Post by 71bird » Sun Nov 04, 2018 8:00 am
Ok, thanks
