What is a deluxe steering wheel with roadrunner emblem (which emblem is proper for a 73)
When it says upper door frame white what does that mean?
Trim grade deluxe looks like?
Trim color black and white: what is black and what is white?
Some Fender code questions
Re: Some Fender code questions
Sometimes those decoders don't do a real good job of describing the codes/options. Throw us the specific codes and we will sort them out for you.
The upper door frame paint code I can help with. On most 71-74 Satellites/RRs, the door panel does not cover the inner door frame completely - you can see some body color paint when the door is closed along the bottom. So the factory painted the bottom edge of the door a similar or same color as the interior.
Trim grade deluxe & Black and white pertains to your seat/interior code possibly? Like P6XW?
Check out this website: http://www.hamtramck-historical.com/index.shtml
And under the library tab: http://www.hamtramck-historical.com/ima ... te0002.jpg
http://www.hamtramck-historical.com/ima ... te0003.jpg
Someone correct me if I am wrong - XW - Black and White interior - Carpet, Dash, and Steering column black, Seats and door panels white.
Looks like that decoder works well for the 72-74 model year cars. Could you let us know where you found that online decoder? Thanks, Scott.
73'BIRD
- My Cars: 1973 Roadrunner, 1974 Satellite
sdweatherman wrote:Looks like that decoder works well for the 72-74 model year cars. Could you let us know where you found that online decoder? Thanks, Scott.
http://www.mymopar.com/index.php?pid=31
Very good! I have not been back to this decoder page since this new version was uploaded. Looks like it is pretty easy to use.
moparite
Get the little white books from Galen Govier, Wealth of info! Well worth the price!!!
http://www.galengovier.com/whitebooks.htm
