71 plymouth satellite sunroof cars made
Jack
My Cars: 1971 Road Runner with factory installed power sunroof 383 4 speed manual
Re: 71 plymouth satellite sunroof cars made
Post by Jack » Mon Feb 27, 2012 10:50 pm
Doright wrote:Ya I have a source for those seals? well the Felt/Lead bulb seal any way the Rubber ones are Hard to impossible to find but the guy who has the felt was working on getting the rubber ones too I need to check back with him.
I need to find another set of cables as well I want to have a back up set just in case along with a few extra Gears.
Source = Kelly's Sunroofs AZ
Hope it helps
Thanks for the info Doright it greatly appreciated. I hope he has 1 seal left I'll let you know how it turns out
Thanks Jack
Doright
My Cars: 72 SE sun roof charger
73 RR clone project
73 RR clone New hemi conversion
57 Chrysler New Yorker 2 dr hemi car
78 TA
a few more but Sold the good ones
Post by Doright » Wed Feb 29, 2012 10:50 pm
Doright
73 RR clone project
78 TA
Post by Doright » Sun Dec 30, 2012 12:15 pm
I revived an IM about Sunroof cars thought this thread should be revived perhaps lots of good information in it.
Jeff
My Tag indicates "H51" for the roof?
BillGass
My Cars: 1974 Plymouth Satellite Sebring Plus 360, 727 Factory Sunroof
Post by BillGass » Wed Jun 04, 2014 4:50 pm
I found this thread while searching for parts for the factory sunroof on my 74 Satellite Sebring Plus. The gears are stripped out and I have not been able to locate any. It is a manual sunroof (moonroof) I was hoping to score some help here seeing that there are some sunroof parts collectors here.
Thanks!
Post by sdweatherman » Sat Jun 07, 2014 12:48 pm
Hey Bill,
Manual sunroof parts are tough to come by, along with the power sunroof components - they are even tougher. I stripped down a 73 Sebring with a sunroof several years back and sold all the sunroof specific parts in less than 3 days! Very few parts are being reproduced. Best course of action is to keep an eye out on the parts forums on Moparts and for B-Bodies only, and check FeeBay once in a while. It would also be very good to put your parts request into the Parts Wanted sections of those forums. That way, people know that you are looking. I will keep an eye out also since I am into the sunroof cars. Please make sure you post a few pics of your ride here on the Nest!
Good luck with your search,
71runnerm51
Post by 71runnerm51 » Sat Jun 21, 2014 10:33 pm
anytime I have to get parts I contact Dave Hemnway in co. :D
BillGass
Post by BillGass » Sun Jun 22, 2014 1:57 am
Scott, thank you for the reply. I will get some pics up when I get her out of the garage and dust her off. She isn't real pretty yet. Drive train is done but the body needs a lot of work.
How would I find this Mr. Hemnway? I tried searching without luck.
Thanks again for the help.
Post by sdweatherman » Sun Jun 22, 2014 2:24 am
Edited: Too many ways to spell that last name!
OK - cross referenced from a post on MoParts
This matches Todd's info below
David Hemenway, Denver Area and ph# is 303-707-5579.
71runnerm51
Post by 71runnerm51 » Sun Jun 22, 2014 8:45 am
Dug a box out of the closet :
David Hemenway
6217 S. Poplar St.
Centennial,Co. 80111
303-770-5579
I found him in the mopar collectors guide about ten years ago :D
road chicken
Post by road chicken » Sat Sep 20, 2014 10:09 pm
Just a follow up. I have a complete 71 power roof and a complete manual roof cassette. I thought it might be a good idea to document both of them since they do not interchange. I'm also having a new cable shoe made for the manual unit, ( where the cables engage the gear). These were made out of aluminum and they wear out causing the cables to slip. I'm sure there are a lot of these out there that think the cables or gear are bad and it's just this shoe that has worn out.
Anyway,once I'm done with that then the manual assembly will go up for grabs.
And as for the power unit, that is getting installed on the chicken. I actually got very lucky with that one. It sat , partially open,in a boneyard for 20 years. I figured it was going to be stuck or at least chunky to move. Surprise surprise, the the thing moves smooth as silk driving it manually. I might hook up the motor and see if it still works as well.
BTW has anyone seen a replacement switch for these? That is the only part I do not have.
Post by sdweatherman » Sun Sep 21, 2014 9:59 am
PM Jeff - 71rm23 - I think he purchased a few extra switches awhile back.
71rm23
Post by 71rm23 » Sun Sep 21, 2014 3:15 pm
O.K. guys,
I have been trying to lay in a decent amount of various Sunroof parts for the electric powered ones. Been doing them a LONG time now. Just contact me with your needs and I will see if I can help. As said, these parts are EXTREMELY difficult to come by. I have been having some stuff reproduced as well. Scott has been letting me know some of you are looking for various stuff. You can PM here if you are looking for something!
Jeff
Moparlar
And a roadrunner clone
Post by Moparlar » Sun Sep 21, 2014 3:52 pm
I believe I have an NOS switch along with weatherstrip ans cables at work. I will check tomorrow and let you know
1971 drag car
1972 440 6pack Roadrunner
roadrunnerron80
My Cars: 1974 Road Runner, factory 318, 4-speed car with a warmed over 340 and 3:91 rear. 1973 Road Runner, factory 340, 4-speed sunroof car Silver Frost metallic with black stripes (needs restoration) 1974 Satellite Custom 6 pass wagon (for parts)
Post by roadrunnerron80 » Wed Dec 10, 2014 8:03 pm
road chicken, do you still have the manual sunroof? I have a car that is missing pieces. Thanks for the info in this thread for the seals.
scottish440
Post by scottish440 » Wed Dec 10, 2014 9:50 pm
Not to water this down... But long ago I had a 71 chrgr with sunroof code that didn't have the sunroof at all.. I was told this was somewhat common do to the outsourcing.. The car had 3 tags and was a fleet car.. Numbs matched the body.. Sound plausible?
====,_ '__..........====,_
..............`~. \__./
..........___.--~\./~--.__
