Power steering conversion from manual
gerardbar1
My Cars: 1974 Roadrunner 340 4 speed
Post by gerardbar1 » Wed Aug 28, 2013 8:09 pm
I have a 74 roadrunner with a 340. It has headers. I want to convert to power steering. What parts do I need besides the box. The pump, pulleys brackets and hoses. Any advice on what I should get and where I should get them. Do I need to remove my headers to take out the steering box. Can I use the same column shaft. What year make and model are the steering parts comparable with
71rm23
Re: Power steering conversion from manual
Post by 71rm23 » Fri Aug 30, 2013 12:50 am
Only recommendation I can provide here is that there IS a difference between the Power steering column shaft and the Manual steering shaft. Find an actual Power steering column from a 1974 model. All you really need is the internal shaft. This can be swapped with your manual shaft in your current column.
Jeff
