73sunroofSSP
- My Cars: 73 Plymouth SSP factory sunroof car
Post
by 73sunroofSSP » Sat Jun 07, 2008 3:28 pm
sunroofs are fun!!!!!!!!!!!!!!!
- My Cars: 1971 Tor-Red RR
Post
by rr6pak » Sat Jun 07, 2008 4:21 pm
Where is this damage at, '72Bird? I would first use some sand paper to scuff it up. 2. Use some alcohol(Isopropyl, NOT drinking, LOL) to clean. Depending on the damage (cant see what is really damaged) might have to put some resin and glass down. Just my 2 cents
73sunroofSSP
Post
by 73sunroofSSP » Sat Jun 07, 2008 4:34 pm
Post
by Smellslike1974 » Sat Jun 07, 2008 4:42 pm
From the pics it looks like the fibers are separated almost frayed,im pretty sure all you need to do is apply resin to glue them together again.But i would ask some one who does this.
Post
by rr6pak » Sat Jun 07, 2008 6:23 pm
72bird wrote:inside the hood scoop won't be seen once i do the isolator plate and cut the hole and mount the seal.
I would scuff the area up before you apply resin though. P.S. make sure it is clean as well
73sunroofSSP
Post
by 73sunroofSSP » Tue Jun 10, 2008 7:58 pm
rr6pak wrote:72bird wrote:inside the hood scoop won't be seen once i do the isolator plate and cut the hole and mount the seal.
Thanks the repair came out perfect. Now to design and mount the isolator plate to use the air grabber baseplate. Can't use a modified SixPak base due to the 2 spd wiper motor.
Post
by Smellslike1974 » Tue Jun 10, 2008 8:07 pm
Thats great everytying worked out for ya.
make sure to post pics when your hood system is setup
73sunroofSSP
Post
by 73sunroofSSP » Tue Jun 10, 2008 8:51 pm
No problem the pics will be in the diary in gen disc.
