383 Cast Cranks
harryhemi
My Cars: 71 Road Runner
383 Cast Cranks
Post by harryhemi » Sun Apr 03, 2016 8:48 pm
Guys,
I was wondering if anyone seen or have a cast crank 383? If in fact they do exist, what years? If the harmonic balancer is the same? Torque converter weighted? I know about forged being internally and cast being externally balanced. I've read so many forums and technical articles that all say something different. :help:
71 Runner 383
Re: 383 Cast Cranks
Post by moparite » Mon Apr 04, 2016 10:45 am
I believe all big blocks had forged cranks up to 1970. After that it depends on the motor.
http://www.moparts.org/Tech/Archive/motor/36.html
harryhemi
Re: 383 Cast Cranks
Post by harryhemi » Mon Apr 04, 2016 6:14 pm
The reason I'm asking is that I have a vibration when idling and when being revved up. The engine is a 70 two barrel and out of a coronet station wagon. All I did was install a mopar camshaft and a four barrel carb. I changed fan and water pump thinking that would help, but it didn't. Only thing that has me wondering is the torque converter. It's for an internally balanced(non weighted) engine. I might have to pull the oil pan off and look at the crank.
71 Runner 383
teddy1500
Re: 383 Cast Cranks
Post by teddy1500 » Thu Apr 21, 2016 11:40 pm
the cats crank was used starting in 71, on the 2 bbl motors only. In 72, the 400 was introduced, with the same cast crank, unless you had a 4 speed, those motors got forged cranks.
quapman
Re: 383 Cast Cranks
Post by quapman » Sun Jun 12, 2016 7:10 am
What's the harmonic balancer look like? Can you post a pic?
harryhemi
Re: 383 Cast Cranks
Post by harryhemi » Sat Jun 25, 2016 8:18 am
Well guys i pulled the pan and its a cast crank. I read numerous forums and other guys said they had also. If someone says they didnt use cast in 70, then they are full of it. I believe its still internally balanced since it has a normal harmonic balancer and the crank counter balancers are drilled.
71 Runner 383
