Page 15 of 35
Posted: Sat Jul 25, 2020 3:33 pm
by 71Beeper
Posted: Sat Jul 25, 2020 3:35 pm
by 71Beeper
Posted: Sat Jul 25, 2020 3:56 pm
by 71Beeper
Can't forget my assistant.....
- July 25 Susans pics (15).jpg (69.21 KiB) Viewed 19285 times
- July 25 Susans pics (43).jpg (129.46 KiB) Viewed 19285 times
Posted: Sun Jul 26, 2020 7:19 am
by 71440 gtx
woooooow i
Posted: Mon Jul 27, 2020 6:23 am
by 71Beeper
Ever since I saw Bruce's RR on this site, I knew I had to go white with mine.
Posted: Sat Sep 05, 2020 5:31 pm
by 71Beeper
So the first order of business was to get some protection inside the wheel wells.
Instead of just going with the usual undercoating, I decided to use this stuff.
- August 9 (4).jpg (135.39 KiB) Viewed 19080 times
- August 9 (5).jpg (137.72 KiB) Viewed 19080 times
Being a truck bed liner, it is tint able, so I bought a quart of W3 enamel to mix into it.
The end result is fabulous! The stuff goes on like butter.
I had to use a smaller roller to apply because a Schutz gun can not spray upside down.
Here's the results....
- August 9 (6).jpg (71.61 KiB) Viewed 19080 times
- August 9 (13).jpg (67.88 KiB) Viewed 19080 times
- August 9 (10).jpg (30.09 KiB) Viewed 19080 times
Posted: Sat Sep 05, 2020 5:33 pm
by 71Beeper
I also put her fender tag back on so she can have some identity.
- Aug 20 (4).jpg (35.3 KiB) Viewed 19080 times
Posted: Sat Sep 05, 2020 5:46 pm
by 71Beeper
The next step is to get a cut & buff done on the clear coat.
The young guy I found to do it in my garage is great.
This is his daily driver...
- Aug 27 (10).jpg (156.73 KiB) Viewed 19080 times
Here he is hard at work.
- Aug 27 (5).jpg (107.21 KiB) Viewed 19080 times
- Aug 27 (6).jpg (95.6 KiB) Viewed 19080 times
- Aug 27 (7).jpg (93.27 KiB) Viewed 19080 times
He's coming over on Labour day Monday to finish it off.
Posted: Sun Sep 06, 2020 2:47 pm
by 71440 gtx
woooooooooooooooooooooow
Posted: Mon Sep 07, 2020 4:41 pm
by 71Beeper
Thanks Kevin - when are you coming down this way to help me assemble it??
Posted: Mon Sep 07, 2020 8:16 pm
by 71440 gtx
i wold love to assemble it
Posted: Wed Sep 09, 2020 11:45 am
by sdweatherman
Holy cow man, I just spent 45 minutes going back through your entire thread on this car. Man you have put some time into this baby. But it just proves that anyone with a little ambition and time can do most of the work on a full blown restoration/resurrection and have a quality product in the end. I look forward to seeing the bits and pieces going back on the car now that the paint is done.
Posted: Thu Sep 10, 2020 8:26 pm
by 71Beeper
Scott, you certainly helped me by supplying the door that I needed
Yes its been quite the journey for me. You and the others here can relate as we are doing what we can ourselves to try and save some $$$.
Yes I did fork out quite a bit of $$$ for the body and paint but if I gave it ago myself it certainly wouldn't have turned out the way it is now.
Anyway, once Ryan is done with the cut & buff I do need to touch up the area under the dutchman panel. Not enough paint on it.
I had some enamel paint spray bombs made up and will do that next.
After that it's on to the front end to black out the area behind the grille.
Posted: Sun Sep 13, 2020 3:14 pm
by 71Beeper
So the cut and polish is complete now. Ryan finished last night at midnight.
He put a final coat of wax on it. This is the stuff he used.
- Sept 13 (2).jpg (89.29 KiB) Viewed 19025 times
The car certainly is shinier than before - and when it was painted it was shiny.
These indoor pics may not do it any justice.
- Sept 13 (4).jpg (69.24 KiB) Viewed 19025 times
- Sept 13 (7).jpg (66.39 KiB) Viewed 19025 times
- Sept 13 (10).jpg (86.13 KiB) Viewed 19025 times
- Sept 13 (11).jpg (87.09 KiB) Viewed 19025 times
Posted: Sun Sep 13, 2020 3:18 pm
by 71Beeper
I finally was able to get this mounted on the wall in the shop today.
- Sept 13 (16).jpg (136.49 KiB) Viewed 19025 times
My wife bought it as a birthday present some time ago - but because the shop was a mess with the underside bead blasting I didn't want to hang it then.
I think it looks good in it's new home.
- Sept 13 (13).jpg (98.03 KiB) Viewed 19025 times
- Sept 13 (14).jpg (114.79 KiB) Viewed 19025 times
