Post by 71Beeper » Sat Feb 20, 2021 5:25 pm
More grunting and groaning today as I installed the leaf springs.
I used the Mopar performance 3/4" offset front hanger and offset rear shackles.
The ones that were on the car when I bought it were homemade ones as this car was a drag car in a previous life, but was not tubbed.
Feb 20 (1).jpg (81.06 KiB) Viewed 16848 times
Feb 20 (2).jpg (67.85 KiB) Viewed 16848 times
Feb 20 (5).jpg (107.28 KiB) Viewed 16848 times
Feb 20 (7).jpg (59.11 KiB) Viewed 16848 times
Feb 20 (10).jpg (84.13 KiB) Viewed 16848 times
Post by 71Beeper » Sat Feb 20, 2021 5:27 pm
And now install the rear diff housing....without scratching anything.... :shock:
Feb 20 (13).jpg (93.52 KiB) Viewed 16848 times
Feb 20 (15).jpg (94.7 KiB) Viewed 16848 times
Feb 20 (17).jpg (65.72 KiB) Viewed 16848 times
Feb 20 (19).jpg (89.16 KiB) Viewed 16848 times
Post by 71440 gtx » Mon Feb 22, 2021 2:56 am
:beer: :D
Post by 71Beeper » Mon Feb 22, 2021 8:06 am
Thanks Kevin.......too bad I didn't have a Dana to put in there eh?? :D
Post by 71440 gtx » Mon Feb 22, 2021 10:36 am
:beer: :lol:
ct71rr
Post by ct71rr » Tue Feb 23, 2021 6:03 pm
Very nice!
Post by 71Beeper » Sun Feb 28, 2021 5:05 pm
Many Thanks guys :beer: As the pieces go on it - its starting to look like a car again.
Not alot done this weekend.
Got the front signal lights installed.
Feb 28 (1).jpg (82.29 KiB) Viewed 16788 times
Feb 28 (2).jpg (113.36 KiB) Viewed 16788 times
Feb 28 (3).jpg (71.71 KiB) Viewed 16788 times
Feb 28 (4).jpg (126.13 KiB) Viewed 16788 times
Feb 28 (5).jpg (105.58 KiB) Viewed 16788 times
Post by 71Beeper » Sun Feb 28, 2021 5:07 pm
And the rear brake flex line bracket.
Feb 28 (6).jpg (63.78 KiB) Viewed 16788 times
Feb 28 (7).jpg (59.29 KiB) Viewed 16788 times
Feb 28 (9).jpg (73.93 KiB) Viewed 16788 times
And I did get the heater box installed.
Feb 28 (10).jpg (198.82 KiB) Viewed 16788 times
Feb 28 (12).jpg (71.06 KiB) Viewed 16788 times
Post by 71Beeper » Sat Mar 13, 2021 5:58 pm
While waiting for bits and pieces to come in I got a chance to sandblast the rear bumper mounts.
My neighbor has an industrial sand blaster in his shop & he allowed me to use it.
I can't believe it took nearly 2 hours to blast them.... :shock:
Here they are just about to be blasted.
March 5 (1).jpg (161.54 KiB) Viewed 16637 times
March 5 (2).jpg (168.59 KiB) Viewed 16637 times
Here they are all done.
March 5 (3).jpg (183.94 KiB) Viewed 16637 times
March 5 (4).jpg (171.2 KiB) Viewed 16637 times
March 5 (5).jpg (161.99 KiB) Viewed 16637 times
Post by 71Beeper » Sat Mar 13, 2021 6:01 pm
Looking closely at the mounts, they have some stampings on them.
Good to see that they are stamped "L" and "R"
March 6 (4).jpg (78.56 KiB) Viewed 16637 times
March 6 (2).jpg (100.68 KiB) Viewed 16637 times
Some part numbers too along with the pentastar...
March 6 (3).jpg (118.62 KiB) Viewed 16637 times
March 6 (5).jpg (78.66 KiB) Viewed 16637 times
March 6 (6).jpg (81.3 KiB) Viewed 16637 times
Post by 71Beeper » Sat Mar 13, 2021 6:07 pm
I put 2 coats of this stuff on to begin with as the steel was pock marked in some places.
March 6 (7).jpg (96.5 KiB) Viewed 16637 times
While the primer was curing I started on the tail light housings.
First I stripped the gaskets and the sealer holding the gaskets on.
March 7 (1).jpg (108.79 KiB) Viewed 16637 times
March 7 (2).jpg (98.36 KiB) Viewed 16637 times
March 7 (3).jpg (87.51 KiB) Viewed 16637 times
Next, the insides needed to be touched up to get that reflective coating back on.
March 11 (1).jpg (137.55 KiB) Viewed 16637 times
Post by 71Beeper » Sat Mar 13, 2021 6:14 pm
Before painting I did check that the wiring and the bulb sockets were okay, which they were.
I must note that these housings were not the ones that came off the car.
I bought these at a Mopar swapmeet some time ago.
Someone took the time to paint the outsides of the housings with grey paint....good job.
The originals were really bad and one of them the housing was cracked.... :mad:
So after the first coat of reflective aluminum paint...
March 11 (2).jpg (151.19 KiB) Viewed 16637 times
Then the finished second coat..
March 11 (3).jpg (144.31 KiB) Viewed 16637 times
March 11 (4).jpg (137.83 KiB) Viewed 16637 times
Here's a shot of one of the original housings....yikes!
March 11 (5).jpg (158.43 KiB) Viewed 16637 times
Post by 71440 gtx » Sat Mar 13, 2021 8:19 pm
:D :D :D :beer:
Post by 71Beeper » Mon Mar 22, 2021 8:25 pm
Now that the tail light housings are painted, it's time to fit the LED light bulbs.
March 18 (1).jpg (118.03 KiB) Viewed 16545 times
Now to put some power to them (don't forget to ground the housings)...
March 18 (2).jpg (114.47 KiB) Viewed 16545 times
March 18 (3).jpg (120.7 KiB) Viewed 16545 times
My phone camera adjusted for glare.
March 18 (4).jpg (83.56 KiB) Viewed 16545 times
Here's all three bulbs lit up.
March 18 (5).jpg (90.95 KiB) Viewed 16545 times
Post by sdweatherman » Mon Mar 22, 2021 11:30 pm
Very cool. I plan to do the same thing. I might have to replace my sockets in my housings first tho. Let us know what the part numbers are on the bulbs - looks like a shorter one for the reverse lights? You need to slow down - you are getting too far ahead of me... :lol:
