My first mopar 1971 roadrunner "sunroof"
scotty82g
My Cars: 1971 roadrunner bahama yellow sunroof
Post by scotty82g » Fri Feb 20, 2009 10:15 am
I have always been a gm guy a few years ago i got to drive a friends charger and from then on i cant get the damn mopars outta my head. i really love the style of the 70s roadrunners so i set out to get one i found my 1971 roadrunner in upstate ny where a friend of mine had it and i never even knew it. one day we were talking about my pontiac ventura and how i wanted to get rid of it and he said i got a car youd like and took me up to a field where the car was just pulled out to make room in his barn.I asked if he would take 2500 for it he said it was probaly worth more but he would sell it to me on the conditions that some day he could drive it again and if i ever sold it he had first dibs how could i not agree with that. so im trying to get some info on the car it is a real 1971 roadrunner was a yellow color now purple full vynil top and a sunroof original engine was a 383 but he gave me a 440 also it has a bench seat and it is a column shifted car i would love any info i can get. like i said i was a gm guy and i really dont know a whole lot about mopars thanks for any help email me if ya want scotty82g@yahoo.com these are some pics http://s673.photobucket.com/albums/vv99 ... 0_0458.jpg
Re: My first mopar 1971 roadrunner "sunroof"
Post by rr6pak » Fri Feb 20, 2009 10:30 am
Welcome, Scott. Need the fender tag numbers and/or the broadcast sheet. We can go from there. Many members here will be glad to help. 8)
scotty82g
Post by scotty82g » Fri Feb 20, 2009 10:39 am
http://s673.photobucket.com/albums/vv99 ... 0_0458.jpg link to my pics
i have the production brodcast im going to just list what i can read it reads
sequence number C090447
vehical order num 914G99098
vehical identification number RM23N1G112968
lease bid sale 13
build for U
Eng 65
Trans 32
axle 53
tires T86
trim code M2X9
udf color TX9
Paint style V01
body paint EL5
roof pnt style top V1X
steering column 351X97005
steering wheel 74X9
horn 78X9
rad 61
inlet hose 14
alt 72
fan 24
fan spa 10
bat 62
vac fit 55
engine 419
carb 30
trans 846
pin 33
p shaft 101
axle 044
wheels 52TX859
wheel cover 24
frame 52
front s bar 62
shock 5662
torsion bar 779778
rear spring 212212
clutch brake pedal 5700
labels 7336
exhaust 9794
tail pipe 9392
car height BP5
mst cyl 31
front brake 1110
rear arm rests 3
seats 2
foam seats 5
carpets or mats 3
drum 11
combination groups 0104
ft heater a/cond upr/vent 41
mirror 3
mirror inside 1
battery 3
oil pres gauge 6
glove box light 1
cigar lighter 5
wipers 5
map lite 5
glove box lite 1
ash rec lite 5
cargo trunk lite 5
fnd/hood turn ind 1
drip through 1
sunroof 1
rr/colored bumper 5
ing switch time delay 5
dual exhaust 1
radio 11
susp 3
shocks 5
power steering 7
wheels 1
at the bottom under remarks it says 1772 and under that 13 oil unit this sheet has way more stuff then the first one i found
Post by 71440 gtx » Fri Feb 20, 2009 11:30 am
that is a 71 charger wh 23C1G1
E24 6 CYLINDER
D14 3 SPEED MANUAL COLUMN SHIFT
ROAD RUNNER ARE RM IN THE VIN NUMBER
Post by Eric » Fri Feb 20, 2009 1:14 pm
welcome Scott, I agree, that broadcast sheet is not for your car. Does it have a fender tag? If so, post the picture and we can decode it for you.
AZ-Nick
Post by AZ-Nick » Fri Feb 20, 2009 7:35 pm
Hi Scott, your RR sounds like a nice car and with a sunroof to boot..... where is that fender tag?
Am I the only one that noticed the B5 interior, are you sure this was a Yellow car?
71 GTX 4sp GY9
70 R/T Challenger - 80's look
AZ-Nick
Post by AZ-Nick » Fri Feb 20, 2009 7:41 pm
I just went back and looked at the picture again and I am sure the hood decal says 440.
Any other pictures?
Is the dash vin or door vin still on the car?
71 GTX 4sp GY9
scotty82g
Post by scotty82g » Sat Feb 21, 2009 2:03 am
yeah the color was with out a doubt some sort of musterd yellow or butterscotch color originally. my friend painted it purple i cannot find a fender tag but the vin on the dash is RM23N1G112968
Post by 1972RM23 » Sat Feb 21, 2009 11:29 am
Cool car ... you can see the butterscotch under the vinyl top.
Post by Eric » Sat Feb 21, 2009 3:24 pm
No way to tell from just the VIN what options the car came with. Looks like it was originally butterscotch....a very cool color IMHO (but I'm a little biased....see the second car in my sig)
Post by 71440 gtx » Sat Feb 21, 2009 4:00 pm
i butterscotch with b5 int :shock: :lol:
scotty82g
Post by scotty82g » Sun Feb 22, 2009 12:00 am
alright im so excited while looking online i found some article that had a section about mopars and how in the factory there was no set place to put the brodcast info sheet and how multiple sheets have been found in cars i started looking around my car and wouldnt you know it i found the sheet behind my glove box taped to it the first one i found was under my rear seat i looked at the vin on the sheet and it matched my roadrunner sweeeeeeeet! im gonna update my broadcast i already posted check it out.
Post by Eric » Sun Feb 22, 2009 12:59 am
So it's an EL5 Bahama Yellow (butterscotch) car with V1X full vinyl top, M2X9 standard black vinyl bench interior, and column automatic. Other options: H41 strato vent, A01 light group and A04 basic group, B11 4 wheel drum brakes, G33 left chrome racing mirror, S77 power steering, R11 AM radio.
I've probably missed something. A readible photo of the broadcast sheet would help.
scotty82g
Post by scotty82g » Sun Feb 22, 2009 1:43 am
i got two pics of the brodcast on my photobucket i would put em on here but everytime i try to it says file is to big so you can use the link to check em out thanks for all the help im learning alot about mopar codes thats for sure
Post by Eric » Sun Feb 22, 2009 4:19 pm
Ok here are a few more for you from your broadcast sheet:
wheel code 52 - 14" Rallye wheels with (code 24) trim rings
axle code (D)53 - 8 3/4" 3.23 open rear end
L31 - hood/fender mounted turn signals (hood mounted in your case)
M75 - rear bumper tape treatment (blackout) - odd, this is usually part of the A87 package, but appears to have been ordered separately on this car
T86 - F70x14 WSW tires
Y13 - dealer demo car
It contains a lot more information, but those are the option highlights.
