413 motor question
- fourforty6pac
413 motor question
Are the early 70's 413 motorhome motors the good ones with extra webbing and better cooling. Are these able to be bored 60 and be reliable? Does everything bolt up the same as a 440 in a car like power steering, a/c, ect.  Thanks.
						- aerodynamic
- aerodynamic
- 72GY9Runner
FWIW....
My father has been rebuilding engines for a living for over 40 years, and for the last 4 years or so has built pretty much exclusively Mopar power plants.
I can tell you for a fact that you will not have a problem boring a later model 400 or 440 to at least .040. As a matter of fact, the block in my runner is a 76 era truck block bored .040.
I have heard him say that .060 over can occasionally cause some heating problems at times due to the thinner castings. That said you rarely have to take a big block Mopar to that oversize unless it was bored previously or maybe really abused.
Just my 2 cents!
Just my 2 cents!
Dave Lutz
Thin wall blocks? I find the information on this site to be a very interesting read on this subject.
http://www.440source.com/blockinfo.htm
- aerodynamic
413
hi  there  they are all wedge motors
LB 350 361 383 400
rb 413 426 440 426 hemi Block
and a 383 rb one year only 345 hp 2 4bbl
Block Bore Stroke CID Block Bore Stroke CID
4.06 3.38 350 4.18" 3.75" 413
4.12" 3.38" 361 4.25" 3.75" 426
4.25" 3.38" 383 4.32" 3.75" 440
4.34" 3.38" 400 4.03 3.75 383 this one
									LB 350 361 383 400
- fourforty6pac
They stopped putting the 413 in cars in the 60's but they still had them in trucks, motorhomes and industrial use, If I'm not mistaken the motorhome blocks have extra webbing inside the crankcase and larger cooling passages in the heads. They also had sodium filled exhaust valves. I cant remember what head was used in them. They were used well into the later 70's. I didnt know what years were the better 413's but after reading up on things at 440 source.com I got the info I needed.  Sure was some good reading there.
