Which RR Nest members have the latest car birthdays 71-74?
My Cars: 71 roadrunner
Re: Which RR Nest members have the latest car birthdays 71-7
Post by dangina » Wed May 22, 2013 7:30 pm
which numbers are they again - my last 6 numbers are 257197
RoadrunnerSteve
My Cars: 1971 Plymouth Roadrunner 340 Auto EV2
Post by RoadrunnerSteve » Wed May 22, 2013 9:24 pm
Here are my '71s:
RM23H1G239551
Date on tag: 707
RM23N1G169467
Date on tag: 122
Post by sdweatherman » Thu May 23, 2013 1:57 pm
Dangina - the build date is on the fender tag. 2nd row from the bottom, 4th group over.
RRSteve - That's a late 71 340 Runner - you just missed by 2 days. RRAddict's RR was built 709.
Post by dangina » Thu May 23, 2013 5:09 pm
is their a way to tell of the date just by the vin number? the last owner lost my fender tag :(
Post by sdweatherman » Thu May 23, 2013 9:00 pm
dangina wrote:is their a way to tell of the date just by the vin number? the last owner lost my fender tag :(
Only if you can find two cars that come from the same plant as your car that closely bracket your VIN. :(
Post by mopar71 » Mon Jun 03, 2013 5:14 pm
sdweatherman wrote:
Eric wrote:
mopar71 wrote:so is that pretty late?
That's fairly early...start of production for 71 B bodies was the first week of August 70
Like Eric said - 71 production started in Aug of 1970 - so your build date is roughly one month into the production year. The sequence number on your VIN should follow suit. They started with 100001 for the first car built that year - My car was built on Aug 26th with a sequence number of 1069xx - so given the trend of about 350 cars per day - and your car being built on Sep 2nd - the last 6 numbers in your vin should be somewheres close to 109000. Am I in the ballpark?
Actually it's 1031xx
Post by sdweatherman » Mon Jun 03, 2013 11:29 pm
I based my guess on St. Louis production. With that low a number, your ride must be out of the Los Angeles plant.
mopardog
My Cars: 1972 Road Runner 400 (project)
Post by mopardog » Wed Jun 05, 2013 4:28 pm
72 RR Dark Green Feb. 9, 1972, prod number 16664* Guessing that codes out to number 6664 (Detroit build) right?
Long live "Ma Mopar"!!! 1972 Road Runner F7 Green, E68, build Feb 9, 1972, Deluxe trim. She's a little rough but she's mine all mine!!!!!
Post by sdweatherman » Wed Jun 05, 2013 10:42 pm
mopardog wrote:72 RR Dark Green Feb. 9, 1972, prod number 16664* Guessing that codes out to number 6664 (Detroit build) right?
mopardog,
The seventh digit in your VIN tells what plant your car was built at. E is for Los Angeles, G is for St. Louis, and R is for Ontario, Canada. I don't have any Los Angeles cars built in 72, 73, or 74 in my database, so they might be a 71 only for 2 Door Hardtop bodies. Since yours is a 72, then St. Louis or Windsor are the most likely build plants for you. The last six digits in the VIN are the build sequence, which started with number 100001 for most makes and models - there are exceptions. So, sequence 100020 would be the 20th car scheduled to be built at that plant. Hope that helps. Scott.
mopardog
Post by mopardog » Wed Jun 05, 2013 11:51 pm
cool, my last six are 166644 according to the vin . you're right, city code turned out to be a type-o on my part. She is a St Louis car....don't try to decode when tired and had a couple of adult beverages I guess. lol
Post by mopar71 » Sun Jul 21, 2013 9:35 pm
Yes my car is an LA built car.
Magnes
Post by Magnes » Tue Jul 23, 2013 11:00 pm
My 72 SSP is from the St Louis plant and the build date is 6/01/72, if that's any help. #207682
