Post
by sdweatherman » Wed Mar 28, 2012 7:20 pm
partfiler69 wrote:My 73 has 803 on the fender tag. So, is that Aug 3? Is that early, or late?
That looks like a very early build date. You can verify early or late by the last six numbers in your VIN. They started the VIN sequence numbers at 100001 at the beginning of the production year. If you are just a thousand or so higher than 100001 - then you have an early build. If you have a much larger number like 248465 - then you are much later in the production year.
Hope that helps! Scott.
partfiler69
- My Cars: 1973 Satty RL21M3G
Former 400, now 440 powered.
Post
by partfiler69 » Wed Mar 28, 2012 9:31 pm
RL21M3G266757
So, I guess i have one of the last ones.
Post
by sdweatherman » Fri Mar 30, 2012 2:01 am
partfiler69 wrote:RL21M3G266757
Wow, 803 would be a very late build for 1973. Typically they are starting the next model year by the beginning of August. The 1973/1974 change over might be a special case though. The big wigs at Chrysler knew that 1974 would be the last year for the Satellite line, and they were not going to make any major changes to the body - just some minor trim changes. Therefore, they may have extended the 1973 production a few more weeks because no major tooling needed to be done. Very interesting - thanks for sharing! I will update the list with your ride.
gcoupe72
Post
by gcoupe72 » Fri Mar 30, 2012 11:25 am
If the sticker on the drivers door is still legible, you could see if it agrees.
And you could look for date codes on the wiper motor and trans. case to see when they were built.
Also check all the glass!
partfiler69
Post
by partfiler69 » Fri Mar 30, 2012 12:54 pm
gcoupe72 wrote:If the sticker on the drivers door is still legible, you could see if it agrees.
It's still at my old place, I plan on getting it here next week. All I have here is the title and fender tag.
partfiler69
Post
by partfiler69 » Tue Apr 03, 2012 12:44 pm
I got my Satty home last night. Looking at the door tag, it has a date of 7-26-73.
Post
by sdweatherman » Fri Apr 19, 2013 10:52 pm
July 26th makes more sense. I have 2 RR's in my database that straddle your VIN that were also built on 7/26. Scott.
asuperdry
- My Cars: 1972 RH23
Post
by asuperdry » Sat Apr 20, 2013 4:12 pm
My 1972 RH23 is a B11 = 11/11/1971
Post
by sdweatherman » Sat Apr 20, 2013 8:37 pm
asuperdry has the latest by default! Thanks for sharing your car's birthday. Scott.
asuperdry
Post
by asuperdry » Sun Apr 21, 2013 11:25 am
my tag....
- My Cars: 1971 roadrunner
Post
by mopar71 » Thu May 09, 2013 11:09 am
Where is the date located on this tag ^ b11? I will have to look at mine.
1carcrazyguy
Post
by 1carcrazyguy » Thu May 09, 2013 2:18 pm
mopar71 wrote:Where is the date located on this tag ^ b11? I will have to look at mine.
9=Sept
A= Oct
B= Nov
C= Dec
So B11 would be November 11th
1971 Satellite Sebring Plus - EV2 / V1W / P6XW Not very nice but it is still wearing original paint and hose clamps!!
Post
by sdweatherman » Thu May 09, 2013 11:01 pm
The date code on our tags is on the second row from the bottom, 4th group over. 1st digit is for the month - 1-9 for Jan through Sep, A-C for Oct through Dec. The next two digits are the day of the month. So in the above example, B11 would be November 11th. Scott.
gcoupe72
Post
by gcoupe72 » Fri May 10, 2013 8:24 pm
sdweatherman wrote:asuperdry has the latest by default! Thanks for sharing your car's birthday. Scott.
I agree, but Nov 1971 would be in the first half of 1972 production?
Post
by sdweatherman » Fri May 10, 2013 10:29 pm
Yep, he is still in the first half of production for the 1972 model year. But nobody else on the Nest has volunteered a later date! My criteria is RRNest member cars - so he has the latest 1972 Sebring so far. Scott.
