1972 SSP 400-4BBL Progress
Re: 1972 SSP 400-4BBL Progress
The Chrysler 8-3/4" rear axle assembly was introduced in 1957. It is a banjo-type (Hotchkiss) axle, ie. the differential is contained in a removable carrier assembly. The axle has an 8-3/4" diameter ring gear. There are three basic types available distinguished by their drive pinion stem diameter. The 8-3/4" axle was the primary axle assembly and saw continued use until 1974.
the 1972 a body was the last year for 8.34 1973 a body have a 8.25
DixieSatellite
How the car usually is when I get to play with it....
Washing off the dust
All clean again
Engine bay work should be completed end of next week.
Interior requires a fair bit of work.
Ian B.
All clean again
Ian B.
woooooooooooooooooooooow nice car
are those guards around the door locks to keep your paint from getting scratched??? pretty cool item - probably won't find those anywhere
DixieSatellite
Hi,landon1 wrote:are those guards around the door locks to keep your paint from getting scratched??? pretty cool item - probably won't find those anywhere
Yes, they were on the car when it was bought back in 1991. Same for the door edge protectors.
Latest engine pics here.
Before
Now
Ian B.
- ct71rr
Very nice
DixieSatellite
dartomotive
Good chart. I really like the white. This is going to be an awesome car. Good luck. Mike
DixieSatellite
Some more progress pics for those interested.
Ian B.
Ian B.
Love it, I am also restoring my 72 Sebring Plus as a survivor car, you just do not see many of them done this way any more. Nice to watch it come together and very helpfull to me as well.
1972 Clonerunner
When I was growing up my Dads everyday driver was a 1972 SSP. It was powered by a 400 4 bbl 4 speed. He had headers on it , man I can remember the roar when that old Thermobog kicked in. It went like crazy for what it was. He drove the snot out of it, that old 400 wouldn't quit. It was orig brown on the top with gray on the bottom with a green interrior , he had it repainted green . Buckets and console car. Loved that car.
Check out my cardomain page about my Sat project. http://www.cardomain.com/ride/3312538
DixieSatellite
Are you sure that guide Is100% accurate?Can anyone approve this?ha ha
DixieSatellite
Deleted
Last edited by DixieSatellite on Fri Sep 04, 2009 7:24 am, edited 1 time in total.
DixieSatellite
Hi,
Engine and air-con system (ice-cold) are finally together, which has pretty much finished my budget for now. Here are the latest pics as to what a factory new '72 Plymouth Satellite Sebring Plus 400-4BBL should look like (well, in the engine bay, anyway). The rest of the car needs a some more beautification and attention to the bodywork, but more has been done in the last 16 months than in the last 16 years.
For those interested :-
Engine Specs
Chrysler 400, Bore 4.372, Stroke 3.380, Cylinder volume 831.51 cc Total volume 405.9 CI, Intake valves 2.080, Exhaust valves 1.650, Compression ratio 9.00, Manifold Dual-plane std-flow, carb flow 800.0 CFM, peak Horsepower "304.3", Peak Torque 414.8. This engine will run fine on pump fuel with a increase in horsepower of 30% over stock engine.
Designed to be mild rather than wild, but able to cruise all day long well above the limit w/ lots of 'passing power'.
Ian B.
[/quote]
Engine Specs
Ian B.
[/quote]'72 Plymouth Satellite Sebring Plus 400-4BBL
