Re: Daddy's Stinky Car progress page - updated for 2020.
Post by 71Beeper » Thu Aug 06, 2020 7:25 am
Scott, as usual you are da man!
Thanks!
Post by sdweatherman » Thu Sep 10, 2020 5:31 pm
Little by little when I have the time. Prepped the passenger side door jamb and cowl and got an initial layer of paint on it. Will seam seal the cowl area and put a second coat on in the future. Cut the rust out of the lower passenger side windshield area and tack welded in the patch. I will work on getting the windshield channel patch made before doing final welding and paint.
Post by 71Beeper » Sun Sep 13, 2020 3:19 pm
Scott, you are doing a great job!
Keep pluggin away at it!
Post by sdweatherman » Mon Oct 12, 2020 11:20 pm
Making the rust go away! Used the existing window channel to fabricate the patch. Slapped on some weld through primer and zapped it down. Forgot to take a picture of the finished and polished welds before I zapped it with chassis black. On to the other corner of the windshield!
Post by sdweatherman » Fri Nov 06, 2020 8:04 pm
Driver's side windshield channel corner has been repaired. Got some primer on the driver's door jamb area too while the weather was nice. Still have a few more windshield channel repairs to go!
Post by rr6pak » Fri Nov 06, 2020 11:40 pm
Looks good!
Post by 71Beeper » Sat Nov 07, 2020 11:36 am
Its crazy on how these cars were prone to rust in this specific area.
Some worse than others.
Scott, mine wasn't as bad but still required patches.
April 16 (1).jpg (62.29 KiB) Viewed 271465 times
My cowl area was pock marked, but not rusted thru.
So I skimmed a coat of All-Metal on it and smoothed it out.
April 16 (3).jpg (49.71 KiB) Viewed 271465 times
April 16 (4).jpg (83.51 KiB) Viewed 271465 times
Post by sdweatherman » Sun Nov 22, 2020 10:14 pm
Keepin' it going. One last patch was needed in the lower windshield channel. The weather has been holding pretty good up here in the great white north. Was warm enough one day to get some primer laid down. Now on to the two bad spots in the upper section of the windshield channel.
Post by rr6pak » Mon Nov 23, 2020 10:35 am
Coming along nicely. Scott. On a side note I'm well aware of the "Great white North". I grew up in ND and some BRUTAL winters we had and later survived the flood of '99
ct71rr
Post by ct71rr » Tue Dec 01, 2020 5:07 pm
Awesome job! Keep the updates coming!! I need to make the same repair on my driver’s side. My window channels look nice though.
Post by sdweatherman » Fri Dec 11, 2020 9:09 pm
Last two patches are in - the windshield channel is completely finished now. Also scored an Edelbrock Performer intake for my little souped-up 318 build.
Post by 71Beeper » Sat Dec 12, 2020 6:29 pm
You'll like that intake Scott.
It's a great intake for a 318.
Not so good for a 360 - the ports are too small.
If you find an Air gap intake for a good price grab it.
Post by Eric » Wed Dec 16, 2020 12:25 pm
I see you're planning to install wire wheels on it :lol:
Post by sdweatherman » Wed Dec 23, 2020 3:27 am
A very classy option! :lol:
Post by 71440 gtx » Mon Dec 28, 2020 3:45 pm
:beer: :D looking good
