I was wondering if anyone seen or have a cast crank 383? If in fact they do exist, what years? If the harmonic balancer is the same? Torque converter weighted? I know about forged being internally and cast being externally balanced. I've read so many forums and technical articles that all say something different.
383 Cast Cranks
383 Cast Cranks
Guys,
71 Runner 383
				moparite
Re: 383 Cast Cranks
I believe all big blocks had forged cranks up to 1970. After that it depends on the motor.
http://www.moparts.org/Tech/Archive/motor/36.html
Re: 383 Cast Cranks
The reason I'm asking is that I have a vibration when idling and when being revved up. The engine is a 70 two barrel and out of a coronet station wagon. All I did was install a mopar camshaft and a four barrel carb. I changed fan and water pump thinking that would help, but it didn't. Only thing that has me wondering is the torque converter. It's for an internally balanced(non weighted) engine. I might have to pull the oil pan off and look at the crank.
									71 Runner 383
						Re: 383 Cast Cranks
the cats crank was used starting in 71, on the 2 bbl motors only. In 72, the 400 was introduced, with the same cast crank, unless you had a 4 speed, those motors got forged cranks.
						Re: 383 Cast Cranks
What's the harmonic balancer look like? Can you post a pic?
						Re: 383 Cast Cranks
Well guys i pulled the pan and its a cast crank. I read numerous forums and other guys said they had also. If someone says they didnt use cast in 70, then they are full of it. I believe its still internally balanced since it has a normal harmonic balancer and the crank counter balancers are drilled.
									71 Runner 383
